AR-M237 error Codes F9-88 and F6-80
  • PASTech
    • Sep 2010
    • 192
    I have been scouring forums and sharps site for information and help to resolve this problem.
    I have an AR-M237 that is error coding F9-88 and F6-80.
    I have read up in the manual, reseated the fax board, gone in and out of this machine and can't find the problem.
    help Please.
    What's Brown and Sticky?
    -A Stick
  • bilyahn
    • Dec 2006
    • 1470
    What is the version ROM on the FX7? If you have the 4.01 it might cause this problem. You should have the 2.xx version. Had a similar problem with the MXM260 and was using the wrong ROM version (uses same fax)
    Good luck.
    Bil
    • OMD-227
      Yeah, I'm with Bill on this one. Firmware upgrade everything first. If that fails, remove the fax/print boards and bootup without them installed.
      • ZOOTECH
        Senior member of CRS
        • 3375
        With a fax error and a print error, the problem might be with the mother board.
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1888
          The engine firmware will update the fax board. Make sure you do the print board also as it's a separate firmware update. If it has a DSK, the print board firmware is included in it. The manual says it can be done serial, but it can't. Network, FTP etc.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • Trompeter
            • 38
            Some of the problems caused by failure of the battery on the Fax-board. There is an 'Andromeda' Fax Battery replacement manual. You can check the battery voltage with the plus probe on JP4 and the minus probe on the minus (-) terminal of C257. If it is OK the battery voltage is 3.0V of more.
