AR 337
  • iscott
    • Mar 2010
    • 344
    AR 337
    I have a AR 337 that a friend wants me to set up to print I think I have found the correct driver.
    And can Ping the machine but I can't get it to print.
    Seems like there was a trick to setting the machines up but I cant recall
    I have been going through Add printer and selecting the IP port.
    • 23009
    The most common mistake on Cougars is to have the SCSI cable connected to the wrong SCSI port or not having that port switched On. If I remember correctly, in sim 26 you'll find a place to enable/disable each SCSI port. They're labelled A & B.
    There also is an extremely high failure rate of those print cards. If you can find one, it won't be cheap.
    More in a minute. I'm searching.... =^..^=
    Only one additional recollection. It was common to have the print card lock up or "F9-00". Most of the time the print card will reset. You must disconnect the network cable, run sim 14 (reset), exit service mode, power Off/On, once the machine has completely booted up (~3 minutes) reconnect the network cable.
    I seem to recall print settings of 'lpr' and 'RAW'. =^..^=
    • Dark Helmet
      • May 2009
      • 854
      If i remember correctly you had to use LPR
      In the Port Tab configure the port your using and choose LPR printing, Enable byte counting and use a queue name of lp (lower case)
      God im glad i don't have any more of these under contract. Hate that document feeder.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1887
        I'm disappointed in you guys. The Cougar printed on port 10001 instead of 9100 for some unknown reason. Change it in the ports tab.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • iscott
          • Mar 2010
          • 344
          Would I still be able to ping it....
          If the Port was mot set up properly?
          • tmaged
            • Oct 2008
            • 1887
            Yes, it's at the same IP address. the port is almost like a subaddress. You can have multiple ports on that address.
            Hope that helps !
            -Tony
            www.dtios.com
            • DINGO
              • 661
              re
              Hi
              Y have same, and are working, like tmaged said, in 10001 por RAW.
              And work better whith PS drivers.
              good look
