sharp ar-m700u with f2-37
  • T911
    • Jun 2007
    • 628
    I know i have to do a drum and blade but is there a calibration for the drum replacement on this one. I do not see anything mentioned in the book unless i'm missing it. thanks t
    • 23008
    Oh yes.
    Before you start, check sim 44-02. You'll probably see readings for one or both sensors at 226 (DMLED & PCLED).
    When you're changing the drum, be sure to thoroughly clean the drum mark and drum patch sensors. A common cause for this code is a failed lower cleaning seal or drum blade allowing toner to spray right on the drum mark sensor. Sometimes it's just normal wear on the drum causing the high readings. Normal readings are around 40.
    Then go to sim 44-02 and run the PROCON Gain Adjustment. It will re-initialize the sensors. Run sim 14 to reset the error. Reset your drum counters and you're good to go.
    The code won't clear, and the sensors won't initialize without running the simulation. That goes for any machine with a drum mark sensor back to analog days. =^..^=
    • bilyahn
      • Dec 2006
      • 1470
      We also use the AR620KA maintenance kit when we do the drums if they are getting a lot of F2 codes. Comes with new toner seal, side drum seals, etc. Well worth the added expense on this model if you are not already using it.
      Good luck.
      Bil
      • T911
        • Jun 2007
        • 628
        thanks so much guys. much appreciated. T
        • Dark Helmet
          • May 2009
          • 850
          When you close the drum frame back up don't forget to plugin the drum mark sensor! So many people do that and get call backs for F2 codes. You will also get light copies.
          • OMD-227
            The only thing I can add to this, is to make sure the drum/dev rotation counters in 24-11 are reset as well as the page counter for each item when you do this service call.
            Every single Dragon/Dragon2 that I service has the 620KA kit every 300K. I have 4 of them in my car right now! You'll never get trouble codes like that if you take the extra 5mins to replace the seals, blade & grid included in the kit. I never replace a drum without the 620KA kit at the same time. Its well worth it!
