ar-m450n jams
  • DINGO
    • 661
    ar-m450n jams
    Hy friends
    First,good night.
    I have some ar-m450n that is giving me the first cassette jam.the problem is intermittent.
    The paper stay , or leaves a bit from the tray.?????
    I already change the three paper feed rollers.
    Appreciate any help, thanks
    • 23002
    What jam codes? =^..^=
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1874
      Check the two tabs at the bottom of the black plastic plate on the left door. They put pressure on the guide & only affect try 1.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • spotlifter
        • Mar 2008
        • 65
        I would go for the main gear box. There's a clutch for tray 1.
        sigpic
        • DINGO
          • 661
          re
          Thanks friends, for all replys.
          -I go see the jams codes and after post here.
          -the two bottons do not are broken.
          -The clucht on the main drive, i go let for the last, ufff!!!
          one more time, thanks.
          • DINGO
            • 661
            re
            Hummm??
            I was thinking about, and i think that the problem is in the main drive box clutch, because sometimes the paper stay in tray, do not move, and gives me jams, and happens more when the copier beguin work on the next day. Happens always in the first copy.
            • Silvertoast
              • Feb 2010
              • 270
              have u replace the torq limiter and oneway, if not try swappin those and scuff up the shaft that the one way is on so it doesnt slip. if this isnt the problem, then i agree with the main drive.
              • DINGO
                • 661
                re
                Hello
                Yes, i never replace the torqu limiter, and i do not know where is it?
                Sorry, but i c'ant translate all your coment, but thanks, thanks any way friend .
                • tmaged
                  • Oct 2008
                  • 1874
                  The torque is on the separation roller shaft & the one-way is on the feed roller shaft
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  • DINGO
                    • 661
                    re
                    Ah
                    ok tamaged, now i understand
                    thanks
                    • duplicator
                      faced this problem changed the feed clutch and solved it......the problem was the feed clutch not engaging properly (slipping) when in feed cycle but if run the simulation it seems fine it only happens during feed cycle.
                      • DAR
                        • Nov 2009
                        • 26
                        Paper Jams
                        Dave Rubelkie with Minolta Corporation would always tell us "Check the Paper"!
                        • duplicator
                          yep its always check the paper!
                          • mrwho
                            Major Asshole!
                            • 4299
                            If you need some help translating from english to portuguese, PM me - I'll be glad to help!
                            Cheers!
                            Mascan42
                            Ibid
                            • DINGO
                              • 661
                              thanks
                              Hello friends
                              Thank you for your kindness.
