Sharp ARM-162
  • tcypy1961
    • 773
    Sharp ARM-162
    I took over the service of this copier this year and the copier had 187,155 copies on it. I changed the developer, and replaced the drum and drum blade. The copier is having a problem where the developer tends to be falling off the developing roller and into the paper path and getting on the copies. The problem seems to mainly be happening in the front side of the copier. The copy count now is 211,949. Any thoughts to what would be causing this problem? It doesnt appear to be coming out of the bushings on the developing unit and the main charge is dusted up each time. Any help appreciated, thank you.
  • OMD-227
    If the charger unit is getting toner dust on it, that eventually leads to dev pull.
    The process unit has been modified (from Feb 2006 production run), with different seals, stirring sheet & sub-blade. These mods prevent the issue from even starting to spray toner onto the charger & then pulling dev.
    Check the serial number of your machine.
    If you'd like a complete list of the parts, send me your email.
    • salmandol
      • Mar 2009
      • 107
      If the charge grid loses its tension it also pulls dv off. i have had to replace a few charge units on these machines
        • 23006
        Did you mention what the problem is?
        By the background information I infer that it's some sort of image quality issue. =^..^=
        • OMD-227
          It would be dev loss, leading to copy quality issues, caused by toner spray/dust on the mc grid. I too think that is what he's saying.
          • pjdbm
            • Sep 2007
            • 360
            replace the mylar on the developer unit, they tend to "curl in" and cause developer to drop in that area and eventually loss of developer to the point where copies are bad.
            • oldrn
              • 166
              Is the machine level front-to-back? Does the dusting on the charger only happen on the machine front side as well? The curling mylar can knock the dv off the mag roller but it seems like they usually curl in the middle rather than on the ends but still worth checking.
