F3-12
  • tmanamore
    • Sep 2009
    • 74
    [Error Code] F3-12
    Can anyone tell me what a F3-12 code on an AR-M550 sharp could be?
  • cetverooki
    • 53
    F3 12 Tray 1 lift-up trouble
    open from back and check if tray lift motor is ok. remove it and check if shaft is straight. Had same problem where user has placed too much paper in wrong position and shaft got bent.
      • 23008
      Don't overlook the easy things, like paper crammed into the lift drive coupler. And you need to do a simulation 15 reset. =^..^=
      • OMD-227
        Another cause of this is generally poor loading of the tray. A big bunch of folded over paper at the bottom will do it, so will a busted lift motor unit, paper empty sensor assembly or pwb in the rear frame.
