MXB401 fax memory?
  • glewisme
    • Nov 2009
    • 240
    MXB401 fax memory?
    Hey gus I've got a weird one here. I just setup a MXB401 that I just installed a MXFXX3 but when I do 22-10 or run 22-6 the fax memory should show up as ARMM9 but it doesn't.I swapped the memory from another new fax unit but still nothing any ideas?????
  • Dark Helmet
    • May 2009
    • 835
    Make sure you have the memory in the proper slot. They move the slots around from model to model. Ive done it before, machine will fax fine just won't show the memory.
    According to my book the memory goes in slot E.
    If you look close on the MFP's they have a diagram of what each slot is.
    • OMD-227
      Agreed.
      The new machines has a different memory slot. Check your install manual.
      You know its wrong when you go into Image send mode and the receive memory says 0% before you even send the first page.
      • glewisme
        • Nov 2009
        • 240
        Thanks guysbthink I got it. For some odd reason the DSK won't allow me see it in 22-10 or 22-6 works though.
        • OMD-227
          Thats interesting......???
          I'll check that out next time I see one. You should be able to see it, even just listed as optional memory.
          Whats more interesting is that you have a DSK in a Frontier! Wow!
            • 22996
            Dvorak Simplified Keyboard?
            Dvorak Simplified Keyboard - Wikipedia, the free encyclopedia
            • Silvertoast
              • Feb 2010
              • 270
              DSK data security kit ????
              • OMD-227
                Data security kit
                • glewisme
                  • Nov 2009
                  • 240
                  Yup guy's still working great I scanned 50 b&w test targets w/out dumping and recieved the same 50 in return so I know the memory is there.Customers having no issues either!
