ar-m450 lift motor
  • DINGO
    • 661
    ar-m450 lift motor
    Hy friends
    Teh lift motor of tray one do not work.
    i already replace for another, good and is the same.
    Any help please.
    regards
    • 23006
    Have you run a sim 15 reset, then powered Off/On? F3-12 and F3-22 require a reset before it will attempt to lift again. =^.^=
    • DINGO
      • 661
      Thanks blackcat 4866
      The copier do not give me code.
      Anyway, after reading your suggestion, i ran the simulation 15
      and after ran the sm 15 the lift motor stay ok, but when
      i try take a copy from tray 1, gives me jam paper, but the
      paper do not move, and the tray 1 stay out of service,
      and of corse the lift motor do not work again.
      If i perform again the sm 15 the lift motor
      stay ok again.
      In the next week i see better.
      thanks again friend., mi best regards
        • 23006
        Any time. =^..^=
