It's uncommon to replace a power supply on a Panther. More likely, the right door interlock is not being made. It's actuated by the right-door rear rail. You'll have to pull the back cover and move the main harness to see it. =^..^=
First thing to check with that series of machines is to confirm if the fuses are OK. Its common for the main power switch to partially flick on/off really quickly if its not pressed correctly, causing a fuse blow. There was a modified AC power board from memory, or you could just put in a slightly higher rating fuse. Its the one closest to the harness from the switch. I haven't touched one for years and years, but I remember this case really well. I always got away with the slightly bigger fuse rating. It just helped with the flashback from the switch.
