AR-M455N Scanning
  • tmanamore
    • Sep 2009
    • 74
    AR-M455N Scanning
    How do I set up a Sharp AR-M455N to scan to dessktop? I have already place a scan folder on my c drive and set it for sharing. How do I get the machine to see it?
    • 23009
    I've only done it a couple times, but I think that you need to install Sharpdesk3.2, then scan-to-FTP.
    Somebody correct me if I'm wrong. I don't think straight Scan-to-SMB is possible. =^..^=
    • ZOOTECH
      Senior member of CRS
      • 3375
      Yes, you are correct; the network scanning option (MX-NSX1) must be installed.
      • nmfaxman
        • 1702
        And sharpdesk requires a licence.
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1887
          You've got excellent advice so far. If the MFP has scanning enabled, you need Sharpdesk & a license to use it. Sharpdesk scans back by putting an FTP utility on the PC. It receives the scan & can move it to a folder on the network. This machine will not scan directly to a folder. The MX-M450N was the first to have SMB scanning.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • xmasvn
            • Jul 2009
            • 70
            that easy way to set scan to desktop
            1 you must install the scan kit in your photo NSX1
            2 after install ok set one ip addr for your photo
            3 and then install sharpdesk on pc you want to san come in this , use auto detect to looking your photo had been install scan kit
            4 when you want to scan on your photo just click on the address chose the name you have set on pc
            5 press enter to start scan this file will be go directly to pc you choose
