AR-M277 F6-10 Code ("FAX Control PWB")
  • Buddy
    • Aug 2009
    • 285
    Hi folks,
    My customer said they're getting the code and they have to unplug the copier in order to reset it. I went out and checked all of the connectors and stared at the machine, but it didn't help...I stared really hard too. Any ideas? Thanks and Merry Christmas!
    • 23009
    I'd start by re-seating all the fax board connectors. The few times this code has come up it was shortly after a surge, and ended up replacing the fax control board. =^..^=
    • divad2k1
      • Sep 2010
      • 147
      Fax batteries can cause this. Check batteries voltage, if under 2.8v replace batterie, if above, may be your fax pwb.
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
        Paul@justmanuals.com
        • Dark Helmet
          • May 2009
          • 856
          Ive had this problem on copiers with network. The NIC drains the battery on the fax board. I copied the first part of the bulletin. If yours has Network and the version is below 1.2.0 replace the battery and setup the copier as described below.
          • Buddy
            • Aug 2009
            • 285
            Thanks guys (except for manuals4you...SPAMMER). I've checked the service and parts manuals and I can't find a part number, or model, of the battery. To save me another trip to the customer, do you know the #? Thanks again.
            • Dark Helmet
              • May 2009
              • 856
              UBATI0014FCZZ
              PM me your email and ill send you the bulletins on this issue.
