AR-M450n, developer issue
  • DINGO
    • 661
    Good night
    I have a problem, with a ar-m450, that is the developer value low very quickly, and beguins give me EL-EE, when i try run sm 25.
    I already replace, developer unit, and the developer, for three times, and the problem continues.
    summarizing, when install a new developer, the SM 25-2 fixed in 125, 15/20k copys
    stay in 70 for exemple.
    appreciate any suggestions...
  • ptrflrs
    Glorified Parts Swapper
    • Dec 2010
    • 192
    are u sure u r using right developer? i think any value under 100 on 25-2 on this model is trouble. i think there is a bulletin for this, u might have to replace the development unit and check the firmware on it.
    jesus loves you! (everyone else thinks you're an assh*le)
    street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
    Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
    • CBMWilson
      • Sep 2010
      • 53
      Yes, make sure you're using the AR450ND developer for North America, AR450DV for EU. Check your local settings.
      • DINGO
        • 661
        Yes,
        I`m using the right dv, 450dv, and i have a lot of ar-m450n and are working with the same
        dv.
        thanks
          • 23009
          Is the developer agitating? A drive issue could cause this problem. Have you pinned out the wiring harness between the developing unit and the PCU? Very rare, but maybe a PCU PWB. =^..^=
          • DINGO
            • 661
            ok
            I'll check these prominors, thanks
