AR-M277 Developer Leak
  • tmanamore
    • Sep 2009
    • 74
    I have a Sharp AR-M277 that is spewing developer around the feed and transfer areas. Is there a seal or setting that is known to cause this problem? Also does it take 1 or 2 bags of developer on a change?
  • OMD-227
    1 bag of dev only.
    Check the upper dev seal is not turned under causing poor dev transport around the mag roller. Sometimes this seal needs replacing.
    Check the MC unit & drum are in good condition, as its common for wear to cause arching & then excessive dev pull.
    Also change the drum separation pawl timing in sim 51-01. Change items 1 & 2 from 50 to 53.
      • 23009
      Like he said. A worn drum will pull your developer. Correct me if I'm wrong, wazza, but I recall reading something about a modified right door ... something about transfer contacts ...
      • OMD-227
        Yeah, there was some changes made, but that was to do with strengthening the door arms (so the door would close properly) and extending the contacts (fixing c/q & transfer issues).
        I read this particular one as more of a dev seal folded over sort of thing.
        We'll see.....
