sharp arm207 paper jam
  • digicor
    • Jul 2008
    • 1159
    there is no paper in this machine, all the sensors seem to be functioning through manually and elecrtonicly testing, yet the machine insists there is paper in the machine. is there a hidden sensor in the pppath? i have looked, thanks for any advice.
  • OMD-227
    What is the jam code?
    • hammer
      • May 2008
      • 111
      I once had a 207 that insisted there was a jam and the user couldn't find it. Turns out they had a jam, removed it, but tore it. The part that was left was (perfectly) behind the reg roller, and only behind the reg roller. It just about affected the sensor here and only by placing your finger on the reg and turning it, did the piece come out. Probably a long shot, but when i saw this at first, visually, there was absolutely no jam.
      • digicor
        • Jul 2008
        • 1159
        thanks for the advice, there is no code by the way , it just says "clear paper path" or something to that affect.
        • Dark Helmet
          • May 2009
          • 868
          Check Sim 22-4
          • bilyahn
            • Dec 2006
            • 1470
            Look just below the drum unit there is a sensor located right in the middle. Whenever I have looked everywhere there is generally a small piece of paper right there. You can remove the paper tray as well and shine a flash light from that side to look. Have had this happen a lot on these machines.
            Good luck.
            Bil
            • zeetac
              You might also have the return spring for the rego sensor off.Have a look at your jam code .It will indicate which sensor.
              • digicor
                • Jul 2008
                • 1159
                the machine has no code, but thanks
                • CBMWilson
                  • Sep 2010
                  • 53
                  There is a jam code you'll just have to check tc 22-4 to see it
                  • digicor
                    • Jul 2008
                    • 1159
                    ok thanks ill do that
