MX-3501N has light prints (black) even with 22-6. System settings print exposure setting is maxed to dark, DR & DV 56k. This machine has basiclly been this way from new. Customer just now seeing it as an issue. Anyone have any suggestions.
MX-3501N light prints
OMD-227
Is this affecting colors as well, or only black?
What is the values of dev stir 25-01 when its finished the cycle?
If the values are close to 128, check toner save modes are not activated, return both system settings Print & Copy density back to normal, run a full color calibration 44-06, 44-26, 46-24, 67-24. -
OMD-227
Problem stated is printing quality, not copying.
However, if b/w printing is faint, copies will be bad as well.
Gotta fix the engine first.Comment
Sorry, I read the post too quickly. You are right either way. Engine must be calibrated first. I remember having light cq problems right out of the gate with some of these. It was only with copying though. If you set exp. to manual copies looked much better.Comment
