MX-3501N light prints
  • tonerhead4u
    • Feb 2010
    • 13
    [CQ] MX-3501N light prints
    MX-3501N has light prints (black) even with 22-6. System settings print exposure setting is maxed to dark, DR & DV 56k. This machine has basiclly been this way from new. Customer just now seeing it as an issue. Anyone have any suggestions.
  • OMD-227
    Is this affecting colors as well, or only black?
    What is the values of dev stir 25-01 when its finished the cycle?
    If the values are close to 128, check toner save modes are not activated, return both system settings Print & Copy density back to normal, run a full color calibration 44-06, 44-26, 46-24, 67-24.
    • mtech
      • Mar 2007
      • 307
      How do the copies look if you take the machine out of auto exposure and use manual (text)?
      • OMD-227
        Problem stated is printing quality, not copying.
        However, if b/w printing is faint, copies will be bad as well.
        Gotta fix the engine first.
        • mtech
          • Mar 2007
          • 307
          Sorry, I read the post too quickly. You are right either way. Engine must be calibrated first. I remember having light cq problems right out of the gate with some of these. It was only with copying though. If you set exp. to manual copies looked much better.
          • glewisme
            • Nov 2009
            • 240
            If it's only on black try setting SIM 46-1 to mode 1 and recalibrate,also as Wazza said sim 25-1 when done should be at or near 128.
            • tonerhead4u
              • Feb 2010
              • 13
              DV bias adjustment took care of the issue. Thanks all.
              • glewisme
                • Nov 2009
                • 240
                By the way sorry 46-19 ,funny I can fix a copier but have yet to learn typing skills!
