arm 355
+ More Options
Posts
  • T911
    • Jun 2007
    • 628
    arm 355
    Jamming out of the upper letter tray. Watching it while feeding out of the tray the tray lowers goes up then lowers again then jams. Is the lift motor getting weak and just replace it or could it be something else. Thanks t.
  • OMD-227
    That sequence of tray lifting then lowering is usually a problem with either the paper empty detect sensor or paper empty arm being broken. A visual check & sensor check in simulation of the paper feed unit will show the problem.
    Its like the machine has not detected that there is paper in the tray.
    Also, what is the jam code you're getting?
    • T911
      • Jun 2007
      • 628
      Thanks wazza ill go back with the sensor too cause I did notice the lever in there. Didn't check jam codes. T
