Hercules Lite Lead Edge seen only in high fill area.
  • moochmurr
    • Jul 2025
    [CQ] Hercules Lite Lead Edge seen only in high fill area.
    Seems to be on multiple machines and Sharp tech tip states to set tc 8-20 TVC timing to default values 25 and or 40 depending on model. We tried setting it all the way to 1 (range is 1 to 99) and the lite lead edge went away. Just ran into this and wondered if anyone else out there as tried this with no other consquences if you left it at the low setting.
