AR-335
  • DINGO
    • 661
    AR-335
    Hello
    y need your help because, y have a sharp ar-335 that sometimes every days give the codes U2-00 , or U2-11, frequently, that y reset whit the simulation 16.
    Y am a tec. and y already do anything that possible that y now, clean, change de c. charges and tranf. units, y try with another pcu pbw, whit another power suply, with anothers flash roms icu, pcu e ope, and y c'ant found the solution, and y do to, a reinitilization the ic-22 in the pcu pbw.
    If someone can help, y do very graty.
    thanks a lot
    • 22997
    EEPROM read/write error (ICU)/EEPROM Counter Checksum Error (ICU). If you have already replaced the ICU EEPROM, the only thing left to do is replace the ICU PWB.
    • DINGO
      • 661
      thanks, y already think that but y only have one icu pbw of one ar-336 and y do no if is the same.
      thanks for all
        • 22997
        You are correct, they are different, and not interchangable.
        CPWBN1325FC54 ICU PWB (AR-335)
        CPWBN1392FC53 ICU PWB (AR-336)
        • DINGO
          • 661
          thanks again, but anyone nows how can be in the icu pbw?? is a frerquently problem?? because y now others 285 whit the same problem???
          thanks
            • 22997
            Just getting old
            I have replaced a total of three ICU's on Cougars. Always for codes. Not until the last year though. The warranty must be up on the electronics. If you have a power supply you may give that a try. I have seen U2-00 & U2-12 caused by the DC Power Supply.
            • DINGO
              • 661
              re
              thanks again, but my problem was in icu pbw , because y change the icu pbw whit another copier that is good, and the problem changed to .
