F2-39 ARM450
  • Dustin(WOP)
    • 223
    F2-39 ARM450
    Hello all
    I have a stumper on my hands. I have an ARM450 that is throwing a bunch of codes at me. H3-00, H3-01 & F2-39. The one that shows up the most is the F2-39 (process sensor). I have reaplce the fusing unit, main board(PCU), power supply unit, drum unit, DV unit, transfer unit, and even the toner cart. This error will not go away!! I read some where that it is the temp/humidity process control sensor, so I went back the book and can not find where this sensor is mentioned any where in the service manual. Has anyone ever had a problem like this? Or can anyone point me in the right direction as to where this sensor is located? I did see on Sharpnet that there is a bulletin for the F2-39 error code and it said that the board in the DV unit was the problem, but I swapped the dv unit with another machine and this code still will not clear!!
    As always ANY tips are greatly appreciated!! THANKS, and happy fixing!!
    • 23010
    Dustin,
    There's a simulation that you must run to recalibrate the PCS. For the life of me, I can't remember what it is. Oh, wait. I'll try a search.
    Of course. First look at simulation 44-01 to see current values. Once you've cleaned the sensor, run Procon Gain Adjustment 44-02. IIRC, the values should drop from ~226 to ~40. Then run simulation 14 to clear the error. =^..^=
    • Dustin(WOP)
      • 223
      thanks for the help Blackcat, which sensor am I supposed to clean? I can not find the PCS sensor anywhere in the service manual or parts book.
      • lky1978
        • Mar 2009
        • 483
        make sure the ar-m450 firmware is updated to latest firmware. the latest firmware for boot m5.03a, main mjc11, pcu 9.04 and scanner 06.04.00
        dont forget to run sim 25-02 after you swap the dv unit and also please check dv unit connector point.
        • mxm
          • Feb 2011
          • 37
          hi dustin in the arm451 the process sensor or humidity sensor is in the dev unit but i like you cant find the process sensor on the arm450 in parts book there must be one as you can check its out put
          maybe try to see if you get a reading from it
          44-09 PTH should give you a temp reading
            • 23010
            Apparently my memory is worse that I thought. There are no drum sensors on the Tiger Series, but I would still run 44-01 then 14.
            • tmaged
              Owner/Service Manager
              • Oct 2008
              • 1902
              AR-P350-SM.pdf
              Here it is Dustin. I'd go with lky1978 & check the connection since you've swapped the DV unit.
              Hope that helps !
              -Tony
              www.dtios.com
              Become a fan on Facebook
              • Dark Helmet
                • May 2009
                • 868
                Ok so i was bored this morning, i took a ARM450 and removed the sensor from the DV unit which gave me F2-39. I plugged the sensor back in and power cycled and the code went away. My meter looked lonely as it has not got used in a while so i took some measurments.
                on the PCU CN8
                With sensor unplugged
                Pin 4 PTH = 3.31V (PCU probably see's this and throws the code)
                Pin 5 Ground = 0V
                Pin 10 +5V = 5.24V
                Pin 11 DVCRU = 0V
                With Sensor plugged in
                Pin 4 PTH = 1.67 (i imagine this will vary a little bit with differnt temp/humidity)
                Pin 5 Ground = 0V
                Pin 10 +5V = 5.24V
                Pin 11 DVCRU = 0V
                Check those voltages out. I know you have replaced PCU, Power supply and DV unit but as far as i can see those are the only 3 things that could generate that code. I doubt it's power supply since this sensor needs 5V and so much other stuff on the copier needs 5V i doubt the dam thing would turn on. I'd still be going with PCU is not reading the proper voltage or your sensor is buggered.
                This wire harness does go into the drive pack. Maybe something happened to it in there.
                If all those voltages check out I guess you will have to go further up the line. Mother board or MFP?
