A0-01 in ar-m236
  • DINGO
    • 661
    A0-01 in ar-m236
    Hello
    I get a code A0-01 in one AR-M236 when i try instal a fx7 fax module.
    one thyng i`m sure, the fax fx7 is good, and work good in other ar-m236 copier.
    any help, i`m glad
    regards
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1876
    A0 01 Content Security incompatibility error
    Details When the PCL or the FAX board is
    installed, it does not match with
    compatible/incompatible setup of the MCU
    board security.
    Cause The security compatibility/incompatibility of
    the installed PCL or FAX board does not
    match with that of the MCU board.
    Check
    and
    remedy
    Cheek the security compatibility/
    incompatibility of each board. Match the
    security compatibility/incompatibility of the
    boards.
    You may need to update ALL firmware. Machine/fax/print
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • DINGO
      • 661
      Good,
      `ve thought about it
      but i`m afraid to damage the copier.
        • 23003
        That's a reasonable concern. Updating firmware on several models of Sharp copiers is a risky business. And you'll require a converter board of some sort. I'll see what I can find out. =^..^=
        • tmaged
          • Oct 2008
          • 1876
          Unless you have a computer with a serial port, you'll need a USB to serial cable. I've done quite a few of these. There shouldn't be any other issues.
          Hope that helps !
          -Tony
          www.dtios.com
          • DINGO
            • 661
            hello
            all oused,
