MX 3501
  • otuvak
    • Aug 2010
    • 102
    [Error Code] MX 3501
    We have a machine that we bumped fused temp up a few degrees. Got an H4-02 code. This has been on again off again problem. Set temp back to default and got code again. Looking for suggestions or if anyone else has had sim problems. Thanks everyone!
  • bilyahn
    • Dec 2006
    • 1470
    How old is the fuser? Have you cleaned the sub-heat roller thermistors? Normally when I start having H4 codes on this machine I rebuild or replace the fusing unit.
