Black copy on Sharp SD-3062
  • blackhat
    Hello guyes,
    I need help on my 3062, i get always a black copy, i checked the drum its always black (the cleaner don t work i think)
    any one can help please ?
    • 23006
    Does the exposure lamp come on when scanning?
    • blackhat
      Hi
      the exposure lamp is working proprely
      • Sam Tofu
        • Dec 2007
        • 130
        By black do you mean solid black. Light black?
        Is it more like a sky shot? or what?
        Few items to check.
        1. It is easy to leave the drum blade "hooked" up therefore not cleaning.
        2. Is the charge being "held" on the drum therefore not allowing cleaning? If this is the case the toner will be more like it is "sticking" to the drum.
        • Copier Systems
          Sharp-3062
          Ck-46-1 settings
          Do exposure cal
          Ck-sim-44-2 44-3
          AndyH
          • Copier Systems
            sHARP-3062
            iF THE DRUM IS COATED ON POWER UP YOU ARE WORKING WITH A DRUM GROUND PROBLEM.
            AndyH
