MX-2610 wont waken from sleep mode
  • sharphead
    • Aug 2009
    • 285
    Orange power indicator light is on but even when the copier is swtiched off and on at the wall it starts again in sleep mode
  • sharphead
    • Aug 2009
    • 285
    I have this up and running again, I tried to perform a firmware upgrade with the CN method but still had no response, but when I disconnected the internal finisher the copier powered up fine.
    I then upgraded the firmware and switched it on and off a few times so far so good.
    • bilyahn
      • Dec 2006
      • 1470
      Thanks for the update. Which finisher did you have on this???
      Bil
      • ZOOTECH
        Senior member of CRS
        • 3375
        Bil
        That takes the MX-FN17 inner finisher.
        • mojorolla
          The Wolf
          • 2594
          I have to laugh at this new machine. Sharp builds this whole new box, new trays, fax kits, etc but the only external finisher is the problem riddled MX-FNX10. I'm not sure which has more retrofits; the new machine or the old finisher. This thing looks like the love child of a MX2600 and a MX311.
          • sharphead
            • Aug 2009
            • 285
            Yes it was the MX-FN17, it was a bit strange hope it doesn't occur again
            • Dark Helmet
              • May 2009
              • 836
              Sharp does not make it's finishers which is why you see the same finisher on so many machines. Many of them are cannon finishers. The Herc series uses Ricoh finishers.
              I have not even seen this machine yet but from what i hear it sounds like it's going to be a POS...
              • mojorolla
                The Wolf
                • 2594
                Had a fuser roll explode on this one today. I mean bits and pieces.
                • Dark Helmet
                  • May 2009
                  • 836
                  And the brochure calls that fuser "state of the art fusing technology" lol..
                  • mojorolla
                    The Wolf
                    • 2594
                    "This fuser roll will self destruct in 5...4...3...2...1...!!"
                    • ZOOTECH
                      • 3375
                      It certainly will if you don't follow the TB for centering the fuser belt at setup.
                      • mojorolla
                        The Wolf
                        • 2594
                        It does it after the centering as well. We received our retrofit pins today and they claim this will solve this on going fuser issue. I will keep my fingers crossed.
                        • vlad_robas
                          • Oct 2006
                          • 225
                          We are expecting to recive soon our 2610 for shoowroom & copycenter i hope it won't blow
                          • glewisme
                            • Nov 2009
                            • 240
                            The machines are great! The fuser is a pain to disassemble and reassemble. You want to do that in your office! So keep a replacement on hand! There are already mods to help with the fuser issues. Also we're not rebuilding the drum units it is a pain as well. It's not worth the extra time and aggravation,just replace the units they're cheap enough. The display can cause sensory overloads so I just dumb it down for our customers! Overall though I really do like them so far,only time will tell though.
                            • ZOOTECH
                              • 3375
                              Even with the pins the belt still travels (I've only seen it travel to the rear so far) but have been assured by help desk that "the belt should not tear". The operative word there is 'should' not would; we'll see.
