Sharp MX-2700n ( F1-33 error )
  • kuby
    • Oct 2007
    • 1400
    I know what the manual says, Finisher punch shift motor trouble, and I runthe SIM3-3 and test FPSM and the error goes away for a while. But it always comes back. It has a punch installed and a MX-FNX1 finisher. It says to check the punch shift motor and it does punch OK. I do not have a service manual for the Finisher Punch Unit to find the part numbers and trouble shoot this. I have not see this machine before, but I got everything working except this. I get all the good stuff.
    Anyone seen this and what to do to fix?
  • kuby
    • Oct 2007
    • 1400
    Is there a way to disable the hole punch and still use the finisher?
    • bilyahn
      • Dec 2006
      • 1470
      Yes, you go into system setting, log into administrator settings (PW: admin), device settings and there is a box to check for disabiling the punch unit. Sharp web site says this is caused by a damaged wiring harness but doesn't give the part number just references the SM. I will look to see if I can find the number for you.
      Good luck.
      Bil
      • bilyahn
        • Dec 2006
        • 1470
        There are 4 cables listed so I'm not sure which one is the correct one as we have not had this issue yet. Sorry I couldn't be more helpful.
        Bil
        • kuby
          • Oct 2007
          • 1400
          Thanks I will try this next week when I get back to the customer.
          • Ingersoll
            • Nov 2008
            • 74
            Re: Sharp MX-2700n ( F1-33 error )
            TT-14134R2 says F1-33 & F1-34 errors
            TT-14134R2
            This supersedes TT-14134R
            Models: MX-FNX1/MX-PNX1B [Options for MX-2300N/MX-2700N/MX-3500N/MX-3501N/MX-4501N]
            Priority: Medium
            Date: Revised October 2011
            Subject: F1-33 and F1-34 Error Codes
            Symptom: F1-33 and F1-34 error codes on the display panel.
            Cause: A Wire Harness in the Punch Unit is damaged.
            Solution: Replace the Wire Harness in the Punch Unit.
            The Wire Harness part number is 0CW1035K219 // and is in section 16, item number 21 in the MX-FNX1/MX-PX1B Parts Guide.
            Or pg 5 (8) section 3, item number 21 in the MX-PX1B Parts Guide CODE:00ZMXPNX1P012
            Bil
