MX-2300
  • vlad_robas
    • Oct 2006
    • 225
    MX-2300
    I have read here a lot of times about the clicking noise that comes from fuser at this machine but now i have one ... I think is coming from fuser (bearings as i remember) is like a train traveling at slow speed and u can hear the rails noise.
    Machine has 210k total. And also had a intresting defect i will post a scan soon.
  • DINGO
    • 661
    hi
    i have this issue to, and when i replaced the upper and lower fuser roller the issue desapear.
    good look, friend
    • The Otrain
      • 54
      Yes, it could be bearings causing flat spots on rollers.
        • 23009
        Read this post.
        http://www.copytechnet.com/forums/sh...nge-noise.html
        • Jhay
          • May 2011
          • 12
          Another cause is a flattened portion, usually on the lower roller.
          • vlad_robas
            • Oct 2006
            • 225
            Thank you all for ur imput. I will take a better look at the fuser and repost.
            Another problem that this machine has is that when print or copy in color mode second page is always comming out with stripes (no matter that is A4 or A3) I will atach to see...
            I have changed the drum units in betwen and the stripes color changed.
            • DINGO
              • 661
              may be a bad blade/drum color, and look the fuser roller???
              • Akitu
                Legendary Frost Spec Tech
                • Oct 2010
                • 2595
                As in the post linked by Blackcat, it could be the K Dev unit.
                • DINGO
                  • 661
                  Hello
                  About the noise, after seeing the blackcat post, in my case i fix it after exchanged the upper and lower fuser roller, because the new fuser units already come with the modification.
                  stay weel
                  • Jhay
                    • May 2011
                    • 12
                    The second page lines could possibly be of bad blades..
                    • efe311
                      • Oct 2008
                      • 114
                      It must be the fuser bearing i have one machine & i change it & work nice
