Sharp MXM503
  • Herbcules
    • Mar 2011
    • 8
    [Misc] Sharp MXM503
    My friend called me today her new sharp says no paper when she's trying to print...
    I haven't a clue on sharps, I'm canon and konica trained.
    I'm sure its a setting.
    Thanks!
  • ZOOTECH
    Senior member of CRS
    • 3375
    The application is probably trying to print to the bypass tray; she can either put paper in the bypass, or press Job Status, highlight the job in queue, press Details and select a different paper source.
    • Herbcules
      • Mar 2011
      • 8
      She she did that and it still says add paper.
      Their tech is on the way.
      Thanks!!!
        • 23007
        My guess? The driver or document is set to some non-standard paper size, or just a paper size not present. Usually it's A4 or A3 in the USA. Or maybe the enduser has selected a specific media type, but has not identified that media type for a tray on the MFP.
        This is a difficult concept for the more careless endusers.
        "Why can't I use just the 'regular' paper type?"
        "Because you're not using just the 'regular' paper type. It's cardstock. It must be set to 'heavy' to fuse properly."
        "... but on my other machine I never had to select paper type."
        "Could you print onto cardstock on the old machine?"
        "Yes ... but the toner kinda wiped off."
        "If you had selected 'heavy' it probably would have fused better."
        "So I have to select 'heavy' every time?"
        "No. Only when you're using cardstock."
        " ... but I never had to select paper type on the old machine."
        and round and round we go. =^..^=
        • Herbcules
          • Mar 2011
          • 8
          Thanks! Yeah I've seen that and I tried to coach her through this with limited knowledge of sharps, nevertheless I'm forwarding her your post, thanks!
          • efe311
            • Oct 2008
            • 114
            Try to select paper source before u print & make sure the document u print is the same size with the paper in the tray u select
