Sharp MX-M620N OPC Drum Life ?
  • scomeau1
    • Mar 2011
    • 100
    How long does this drum last before replacement is needed ?
    Thanks Scott
    • 23008
    300K with few exceptions. =^..^=
    • scomeau1
      • Mar 2011
      • 100
      My MX-M620N has 95K on it but it looks like the drum was replaced as the count on the drum is at 758 copier in the service menu.
      Not sure why they changed it before I bought the machine, The jam codes are showing "0"
      Scott
        • 23008
        .... um, nope. My psychic powers are not getting anything. Maybe Tarot cards might work better? =^..^=
        • Silvertoast
          • Feb 2010
          • 270
          we refurb our older machines b4 we sell them, repl drum dv ectt.... along with cleaning the panels inside and out. mayb the place u bought it from did the same
          • xmasvn
            • Jul 2009
            • 70
            i got one 1million copy still run well
            • RSCA
              • 112
              The spec from Sharp is 250K. I just took over service on one that had 375 on it and one end was worn through to the core and giving a F2-37 error which is mark sensor. If you've got a million, that's cool, but I don't know how.
              • costd
                • Jan 2008
                • 409
                They may have replaced it for any of a number of reasons - to include because it was physically damaged. For us, Sharps tend to run a bit over the rated amount. Normally we will just clear the counters and wait for CQ issues.
                • scomeau1
                  • Mar 2011
                  • 100
                  When you clean the panels do you use a small vac ?
                  I'm looking to by one.
                  Scott
                  • igi
                    • 1507
                    hi
                    just make shure to replace side seals on dv box
                    if the seals worn or not installed corectly will reduce drum life greatly
                    good luck
                    • mojorolla
                      The Wolf
                      • 2622
                      These drums run real well and as mentioned above, rarely go out early. The jam codes showing zero means nothing. I clear my jams codes after every call.
                      • scomeau1
                        • Mar 2011
                        • 100
                        How do you clear jam codes ?
                        Scott
                          • 23008
                          simulation 24-01
                          • scomeau1
                            • Mar 2011
                            • 100
                            Thanks !
