SHARP MXC310 - coloured lines when using doc feeder
  • benn84
    • Jan 2011
    • 26
    hi all
    having a problem with the baby sharp again!!
    This time all prints are ok, copies from the glass are ok, but when using the document feeder random coloured lines appear in image area, i took apart the scanner assy and cleaned as much as possible but problem still present. has anyone had a similar problem? first thoughts are to replace the scanner assy
    regards
    ben
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    First thoughts seem logical... I think every Sharp tech will agree that the scanner ass'y on this unit is a giant facepalm.
    • divad2k1
      • Sep 2010
      • 147
      You have the problem when doing black copies ?
      • benn84
        • Jan 2011
        • 26
        It's fine when copying in black and White, only appears on colour copies
        • Silvertoast
          • Feb 2010
          • 270
          seen this on the bigger sharp color copiers, there is some tiny spec of dust in the optics causing the color lines, fought with one for hours once cleaning over and over again b4 it went away, but would have to agree the tiny scanners on the small ones are crap and if u are able just replace it
          • benn84
            • Jan 2011
            • 26
            Where the lines you were having on the bigger machine in roughly the same place or just random anywhere on the page also how big where the lines you had? The lines I'm getting are randomly spaced and also vary in sizes also some appear quite feint whilst others are very noticeable
            Regards
            • divad2k1
              • Sep 2010
              • 147
              Had a similar problem on a mx5001n, was dust coming out of the feeder. Random lines only in color.
              Cleaning the feeder and playing with some exposure setting did the trick.
              • benn84
                • Jan 2011
                • 26
                How do I adjust the exposure and can the dpi be adjusted for copying?
                • Silvertoast
                  • Feb 2010
                  • 270
                  Regards
                  they were real defined lines that moved around everytime i attempted to clean it, in variyin colors
                  • mojorolla
                    The Wolf
                    • 2611
                    I would check the slit glass for hazing. If platen copies are OK, the CCD should be good as well. If the slit glass is worn, it can fracture the light and cause random colored lines from the doc feeder. Black is usually uneffected in this scenario. Exposure and dpi can be adjusted from the touch panel, at least on a 2600 it can....
                    • benn84
                      • Jan 2011
                      • 26
                      I did notice what looked like wear marks on the slit when I took it apart but seemed to clean off , lines did appear slightly less noticeable but that could have been me hoping they looked better :-s forgot to mention the machine is new
                      • gwaddle
                        • May 2009
                        • 782
                        Go with your first thought. Replace the scanner assy. They are cheap enough, it's not worth messing with.
                        I know I should be ashamed of myself. Strangely though, I am not.
                        • mojorolla
                          The Wolf
                          • 2611
                          Well hell, if it's new file a warranty claim and be done with it!
                          • benn84
                            • Jan 2011
                            • 26
                            have since been told by sharp that the glue used inside the scanner assy has been changed which should cure known faults with them, will have to wait and see when the assy eventually turns up!
