sharp ar-m160
  • marcangel
    • 13
    sharp ar-m160
    hello everybody, I got a service call from this machine and it's just a jammed paper. So I removed the jammed paper but still the jam code is still there. The jam code is in the fuser/exit unit. Is there a resetting code for this code? Thanks in advance for your help.
  • johnbla
    • Apr 2005
    • 94
    Check the Fuser Exit Sensor Actuator Arm and Spring, ensure that the 'flag' at the end, goes into the Sensor housing in the end of the Fuser and that there is no debris in the Sensor housing.
    You may have to change the Sensor on the Fuser, they are not the greatest and being placed next to the hot Fuser does not help.
    regards
    John
    sigpic
    " The Game never ends..When your whole World depends..On the Turn of a Friendly Card..."
      • 23008
      Johnbla is on the mark. Those sensors go intermittent after you cook them for 10 or 12 years next to the fuser. It can work fine cool, then go intermittent when hot.
      • marcangel
        • 13
        There is no resetting method for this jam code. It's just this sensor that's causing the code right. ok thanks sirs. I'll check this part.
        • pjdbm
          • Sep 2007
          • 360
          The jam sensor arm may be missing due to an overly aggressive jam remover. Make sure the black sensor piece is still there .
