arm205 ghosting
  • ash_572
    • Oct 2008
    • 523
    arm205 ghosting
    i mainly work on ricoh. i have a problem on a arm205 b/w copier. the same image seems to print twice on one page. if i change the original, it reprints the same image twice on the same page but giving it the ghosting effect. i have changed the hot roller and pressure roller, the drum unit, dev unit and even the whole fuser unit. when i stopped the copy before it got to the fuser i can see the ghosting on the drum and on the paper but the drum unit was already replaced with no effect.what can it be??
  • vincent64
    • 382
    Check the drum ground pin on the rear of the machine, easy reached through the side door, clean any gunk off, maybe even hit it with a bit of scotch brite pad.
    • ZOOTECH
      Senior member of CRS
      • 3375
      I had a new install once where the LSU glass that reflects the laser onto the drum was put in backwards. So instead of hitting the mirrored side and reflecting, the laser passed through the glass first then was reflected back through the glass onto the drum. This caused more of a double image than ghosting; if the LSU was changed recently, this might be the cause of your problem.
        • 23008
        What interval in millimeters does the shadow image appear?
        • ash_572
          • Oct 2008
          • 523
          if i line the image up by rolling the paper, its the same size as a drum.
            • 23008
            It's fairly common to have the drum blade flip on Pegasus and Panthers. If that is the case the drum and blade are unsavable, require replacement and priming with starting powder. For those of you with rulers, it's 94mm. =^..^=
