sharp ar m257
  • poco
    • Sep 2007
    • 7
    sharp ar m257
    I am pming mach with 191k on it it has never been serviced do i have to reset any counters for copy quality and is trere asim for dev replacement? thanks for any help
  • johnbla
    • Apr 2005
    • 94
    Re: sharp ar m257
    Check PM's
    regards
    John
    sigpic
    " The Game never ends..When your whole World depends..On the Turn of a Friendly Card..."
    • Dark Helmet
      • May 2009
      • 850
      Re: sharp ar m257
      Paul this man needs a manual!
      191k and it's never been touched? The copies must be crap. Drum, DV, blade, charger and probably a fuser (at least clean the felt on the back side of the heat roller). Make sure you take a Q-TIP and clean the TCS sensor off under the mag roller.
      Sim 24 resets your M-counter, drum & DV.
      Once all counters are reset and new DV installed turn machine on with front door open, enter sim 25-2(DV Calibration), close the door and run the sim. Do not power the machine on with doors closed until the DV is calibrated.
      • JustManuals
        • Jan 2006
        • 9838
        Re: sharp ar m257
        This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
        Paul@justmanuals.com
