Admin Password reset
  • sharptech
    • May 2011
    • 40
    [Misc] Admin Password reset
    Hello All,
    I am new to this forum. Glad I found it.
    This is my 1st post.
    I need to find out how to reset the admin password. Customer changed it and can`t remember what it is...dummys.
    T.G.G.
  • PASTech
    • Sep 2010
    • 192
    Re: Admin Password reset
    What model of machine are you looking to reset the password for?
    For MX3501N an like models the admin initialization is SIM 24-30
    Hope this helps.
    For future posts full information does help get a more accurate and prompt response. I know as I have missed some information and then I get a bunch of questions to clarify when I need to get help on the machine and have to give more information before I can help my customers.
    What's Brown and Sticky?
    -A Stick
    • sharptech
      • May 2011
      • 40
      Crap I must be loosing my mind.
      It is a new MX2610N
      t.g.g.
      • PASTech
        • Sep 2010
        • 192
        Oh...one of those....well...
        after finding out all sorts of new things about the machine (searching service manuals and such) I decided to searcht eh Operations manual. I found something...under trouble shooting and the last listed item labeled you've forgot the administor password....and that was useless (thanks Sharp)...tells you to go to the quick start guide which commences to tell you how to set up your password and gives you a handy little sheet to write down your passwords.
        They make sure to note *Please take care not to forget newly set administrator passwords*
        That is where my path died....however I learned a lot about these new machines which I needed to do anyways.
        So thanks for the question...
        Hopefully there is someone smarter that I out there (which would be hard to beleive...jk...see i spelled believe wrong).
        If anyone knows, we'd like to!
        Thanks in advance.
        -A Stick
        • PASTech
          • Sep 2010
          • 192
          I just found a Tech Bulletin about this.
          Sharp Tech tip 1496. basically says you can not reset the admin password due to the need for increased security...Who ever sold/demo'd the machine is responsible for making sure the user does understands the necessity of retaining the password.
          So you are out of luck....not sure if there is anyway around it...try checking with Sharp directly.
          -A Stick
          • bonnie750
            • 302
            there is a small dipswitch on the mfp board which allows the password to be reset. i haven't used it myself but that is the item that does the business.
            Bill
            • PASTech
              • Sep 2010
              • 192
              Thanks Bill!!!
              Good to know.
              -A Stick
              • sharptech
                • May 2011
                • 40
                Thanks for the help.
                T.G.G.
                • redserv
                  • May 2010
                  • 307
                  wow exellent info, did it work with the dip switch, to reset password? please let us know if it works
                  • mojorolla
                    The Wolf
                    I remember the dip switches from class. Upper left hand corner if you are facing the board. From what I remember, you flip the switch, reboot, and password is reset. I have looked in the service manual but found nothing pertaining to this reset. Way to go Sharp!!!
                    • Jokakorn
                      • Feb 2011
                      • 15
                      Very interested in trying to figure out how to do this. I've tried doing the update switch and the sd boot switch individually and together with no password reset.
                      If anyone has the procedure to do this, please post it please. We have alot of customers that forgot/lose/fire the admin password and really would like to have this procedure.
                      Thanks in advance.
                      • sharptech
                        • May 2011
                        • 40
                        The dip switch did the trick.
                        • yousaf
                          • Jun 2010
                          • 43
                          Admin Password how to change
                          MX-5001N how to change administrator password
                          hi
                          can u plz tell me how to change the MX-50001N administrator password. and other thing is there is any option to disable the HDD bcause i want that when i scan or print it will not save to the hard drive. can u plz write me the detale or send me any file that could help me
                          thanks
                          knight
                          • glewisme
                            • Nov 2009
                            • 240
                            The whole reason Sharp didn't make that available in the simulations was for legal reasons, due to the security risk! Thanks for the info on the dip switch though,that info was not made available to us in class in NJ!
                            • Ednicarl20
                              • Aug 2011
                              • 25
                              how do you reset the password??? can you please specify... I have one service call that the operator forgot the password...
                              Thanks'...
