Sharp AR 235
  • mallito
    • Jun 2025
    Sharp AR 235
    I have this copier working with new drum, toner and developer. I make all the manufacturer adjustment, ones I start to make copies, they comes out completely black. I adjust the grey scale, and copy exposure, perform the white adjustment but still making the dark copies without an error code. Need to find help with these problem
    • 22997
    Re: Sharp AR 235
    Are they black copies or just very dark copies? More specifically, is there any original image in your black page? Is the page black all the way to the edge, or are the voids present?
    If no image, and black to the edge, most likely you have a primary charge loss. You may have incorrectly installed the primary charge unit or left it completely out.
    If there is image, and the voids are present, then it's probably optical. In this case, internal prints should look fine. =^..^=
    • mallito
      Re: Sharp AR 235
      If I adjust the exposure to photo mode I can see lightly an image but in text and aouto exposure is completely black from edge to edge. The toner exposure adjustment is 50 in auto exp. and 46 in others..........
        • 22997
        Re: Sharp AR 235
        ... If no image, and black to the edge, most likely you have a primary charge loss. You may have incorrectly installed the primary charge unit or left it completely out... =^..^=
        Go with this one. Once you resolve your primary charge issue, you'll have to re-adjust the exposures. =^..^=
        • igi
          • 1507
          Re: Sharp AR 235
          hi
          100% for black cat advice,if too involved try baby steps sim 64-01
          good luck
          ps black cat stuning avatar,is it yours?
            • 22997
            Re: Sharp AR 235
            Originally posted by igi
            hi
            ... ps black cat stuning avatar,is it yours?
            Stunning, indeed! I am a handsome devil, aren't I? Or are you just admiring my mouse? =^..^=
            • igi
              • 1507
              Re: Sharp AR 235
              yep handsome devil for shure
              the eyes in the pic can tell you a story and a half
              i am also a cat person
              cheers or meow
