Sharp Arm 421u
  • navaneetan
    • Jul 2025
    Sharp Arm 421u
    Hi, I Have A Sharp Arm421u,it Showing L4-02,i Replaced Drum,cleaning Blade Everything,but It Showing Sometime The Same Error. What Is a Permanent Solution?
    • 23007
    L4-02 is Drum motor lock. That is, the drum motor cannot turn. There are several possible reasons:
    1) flipped drum blade.
    2) cleaning unit backed up.
    3) drum motor failure (possibly as a result of cleaning unit backup).
    4) shorting high voltage leads (I know it sounds illogical, but I've seen it on other Sharps).
