Sharp AR-M277
  • Kim Krell
    • Aug 2008
    • 43
    [Error Code] Sharp AR-M277
    Error code L4-01(main motor not turning), I have reset trouble code but comes back after the machine cycles approx 10 seconds. I have inpected the gears, drum, toner and dev. they all turn. I have never seen a main motor go bad, is it possible?
    • 23008
    Re: Sharp AR-M277
    IMHO, possible but unlikely. More likely, something is the drive train is slowing the main drive motor because it has excessive drag.
    I would remove the back cover to hand rotate the main drive motor. Then I would remove various driven components until I find the one that is dragging down the motor. The fuser could cause this. The developing unit could cause this. You won't know until you start hand turning the drive motor. =^..^=
    • Kim Krell
      • Aug 2008
      • 43
      Re: Sharp AR-M277
      I did check these items and rotated them, but I will check again. I am thinking the Fuser.
      Thanks for the reply
      KK
      • JustManuals
        • Jan 2006
        • 9838
        Re: Sharp AR-M277
        This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
        Paul@justmanuals.com
        • oldrn
          • 166
          Re: Sharp AR-M277
          Are you running it in simulation mode when it gives the code or normal warm-up. If normal warm-up, will it run in Sim 25-1 without coding out?
          • jomaridel319
            • Jan 2019
            • 7
            Sharp ARM277 Fusing Unit compatible with AR271FU?
            Hi, I got confussed when I bought a fusing unit AR271FU, it stated that it compatible with AR-M277 machine, but when I open the box, the fusing unit is totally different from the ARM277, can someone already tried to use this AR271Fu to ARM277 machine? Thank you.
              Re: Sharp ARM277 Fusing Unit compatible with AR271FU?
              1) this thread is from 2011 DEAD THREAD
              2) totally different issue
              3) start your own thread.
              • harleyrider
                • Oct 2011
                • 348
                Re: Sharp AR-M277
                He did
