Sharp ar-m236 (maintenance required)
  • rsa
    [Error Code] Sharp ar-m236 (maintenance required)
    MAINTENANCE REQUIRED appeared on the screen of ar-m236. do you know guys whats the problem with this machine? the machine still continue working but I'm bothered with the warning... any help is much appreciated. thanks in advance. I'm new in this field in office equipment technician.
  • igi
    • 1507
    Re: Sharp ar-m236 (maintenance required)
    hi that is the standard message for service time
    so service the copier change the required items and then reset the counters
    good luck
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
      Paul@justmanuals.com
      • alewis69
        • May 2010
        • 10
        just need to reset some of the counters to turn off message....i usually clear counters in 24-04, 24-11-01, 24-01-01, 02, & 03...to enter code-type simulation: copy mode key ON > Program key ON > Asterick (*) key ON > CLEAR key ON > Asterick (*) key ON > ready for input of a main code of simulation....
          • 23007
          No ... don't actually replace any of those worn out parts, just wait until they start falling off the machine. =^..^=
          • igi
            • 1507
            that sounds like our dealers complaining about everything,but dont replace nothing
            ps still like your mouse
            • bilyahn
              • Dec 2006
              • 1470
              It's just another way to drum up business?? If you don't do proper maintenance (like changing the oil in your car) it's just going to cost you A LOT more later when you have to call in a real technician.
              • Dark Helmet
                • May 2009
                • 846
                Depending how old the drum is you won't run into problems on that machine for a while. The M count pops at 75k. Ive taken them up to 100k with no problems. Before you start getting light copies your probably going to get lines from the charger first.
                • Ednicarl20
                  • Aug 2011
                  • 25
                  If you know the simulation just adjust the copy life, let say increase by 5K the next time the maintenace required appear replace the consumables...
