TB-495R2
  • redserv
    • May 2010
    • 307
    TB-495R2
    hello guys, i just recently had a MX2610N fuser belt damaged on one of my clients photocopier,however i am abit confused by the bulletin TB-495R2, the heat roller frame is NOT modified and the heat frame fulcrum plate is NOT modified, my question is what modified part should i change at this point? the fulcrum plate or heat roller frame, i know that i need to get the belt replaced etc. but not sure about which mod to do, thanks in adavnce
  • DavePo
    • Jul 2008
    • 305
    Re: TB-495R2
    Replace the fulcrum it is a hell of a lot easier than the frame.
    • ZOOTECH
      Senior member of CRS
      • 3378
      Re: TB-495R2
      Your dealership should have been sent the modified fulcrum for each machine it bought manufactured before Apr 2011. The p/n on the package is M-05-02-0-1-08, and yes it is much easier to replace the fulcrum rather the plate . Two of our machines that I installed the modified fulcrum and centered the belt at setup ripped within 10,000 copies/prints.
      • mojorolla
        The Wolf
        • 2639
        Re: TB-495R2
        Well that is not good to hear! We have 4 of these in the field and since the mod have not had any problems. The pin is so simple to replace, an end user could do it. Zoo, I will keep my fingers crossed.
        • DavePo
          • Jul 2008
          • 305
          Re: TB-495R2
          Yeah we had six to update and even before the update had not had a belt problem. Though I did see a few where the belt was off center a bit, but not to the point of tearing.
