Sharp ar 201 +L 6-10 code
  • cucuklotz
    • Mar 2007
    • 611
    HI,
    Customer called with code,I saw online that it refers to poly motor.I took laser unit home tonite,and motor seems free and in tact.
    I have to go back tommorrow,is there anything else I need to be aware of that may give me L6-10 service code?It goes into code about 10 seconds after power up.
    THANK YOU, ANDY
  • choicecopyguy
    • Mar 2006
    • 111
    A bad laser motor will look and feel fine. replace it.
    • cucuklotz
      • Mar 2007
      • 611
      Sharp L6-10? AR 201
      HI,
      Ill order motor,
      Thank you, ANDY
      • DAFFY
        • Oct 2007
        • 3
        HI for L6-10 you must change the polygon motor and if you are unlucky may change all the laser unit but usually with the polygon motor it is ok
          • 23008
          Yep, it's always the mirror motor. Most times I'll just call the customer to tell them I've got to order the part. It's fairly common on Sharps & Ricohs.
          • cucuklotz
            • Mar 2007
            • 611
            Sharp 201/ L6
            Hi,
            I just ordered motor.
            THANK YOU,ANDY
            • arriva1
              • Apr 2007
              • 66
              Definitely laser motor and its a fun job especially getting the screw on back side of laser unit. Its fairly common though an after you do it a few times its pretty easy.
              • chakiris
                • 22
                you have to replace the polygon motor inside the Laser unit...
