AR-M700 "Remove Parer from center tray"
  • SteveSJM
    • Jul 2025
    I have never had this one before, any help??
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: AR-M700 "Remove Parer from center tray"
    Check your POD3 exit lever, it might be stuck or broken.
    • mojorolla
      The Wolf
      • 2626
      Check the rear of the drawer and make sure the actuator springs are still there. I Have had a few that paper behind the drawer knocks things loose.
      • SteveSJM
        If you are refering to the exit switch in the "throat" center area it flips up and down fine.
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1887
          Zootech is correct. Check the sensor in sims. I just replaced one yesterday.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
