MX-3110N Simulation
  • RSCA
    • 112
    MX-3110N Simulation
    It must be the end of the day on Friday. I'm setting up this machine. First time with the new series. The set-up says enter simulation with the front cover open to do dv calibration. From the main screen I press copy and I get a big message that says "Front Cover Open" that covers all the buttons. If I close the cover I get a message to install the toner cartridges. What am I missing? The manual is no help.
  • Dark Helmet
    • May 2009
    • 865
    Re: MX-3110N Simulation
    double tap the home button and then touch the VER when the meters pop up. You can then enter P,*,C,* and do 25-2
    It's in the book to
    • Dark Helmet
      • May 2009
      • 865
      Also make sure you have the latest firmware and fuser mod. There is a ton of firmware fixes for these puppies.
      • RSCA
        • 112
        I got it now. Thank you. First time with a new machine is always interesting. Have a great weekend.
        • tmaged
          Owner/Service Manager
          • 1901
          And do NOT even touch the machine while it's stirring the DV. You'll botch it & have to add new DV. Been there, done that. Total BS !!
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • Akitu
            Legendary Frost Spec Tech
            • Oct 2010
            • 2595
            Well I can say I'm quite happy to have not had ours interrupted during set up. What happened in your case, and why did you have to replace the DV?
            • Dark Helmet
              • May 2009
              • 865
              Your supposed to take the toners out
              Im guessing the machine got bumped and some toner fell down the pipe and overtoned your dv?
              • tmaged
                • 1901
                Actually it tells you to remove the toner if you try to run 25-2. As I explained to the hotline guy, the first time you replace the developer, there's going to be toner in the pipes. There's some glitch in the firmware that needs fixed. It's simply touching the display that screws it up. It gave us F2-41 & 42.
                Hope that helps !
                -Tony
                www.dtios.com
                • Dark Helmet
                  • May 2009
                  • 865
                  In that case I will not touch the display
