Sharp AR-M236, Service code U2-40.
  • Hansoon
    • Sep 2007
    • 3385
    According to the manual this is a CRUM chip communication error.
    -Any hints please where to look?
    -How to reset in case its only a temporary error?
    Hans
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: Sharp AR-M236, Service code U2-40.
    Hans
    Check the toner and developer unit to make sure they're completely inserted properly into the machine, try running a sim 16 after checking to clear the error.
      • 23008
      Most times, just reseat the cartridge and run sim 16, like Akitu says.
      The only ones I've ever seen that did not reset, were re-chipped, re-filled cartridges.
      • ZOOTECH
        Senior member of CRS
        • 3375
        Hans
        The connector bracket at the rear that receives the toner cartridge is easily bent if customer/tech forces toner cartridge in. With the rear cover off, you can give the bracket a tap to straightened out and maybe the cartridge will seat properly. Then use TC 16 as mentioned to clear code.
        • BMSInc95
          • Sep 2011
          • 66
          Whenever I have seen this the machine blows the chip and at a minimum you have to replace the chip before sim 16.
