MX-2700N With MXFXX1 not dialing
  • BMSInc95
    • Sep 2011
    • 66
    [Misc] MX-2700N With MXFXX1 not dialing
    In the fax mode if the number is dialed without pressing speaker first the machine will not dial the number and after about 20 seconds it will go into recall mode. tested dialing with 66-16 and works fine but when not in sim. mode it will not which makes them have to dial manually and not able to use the address book. WEIRD!? Please help.
  • DavePo
    • Jul 2008
    • 305
    Re: MX-2700N With MXFXX1 not dialing
    Is the fax memory in the correct slot? Also is memory possibly bad?
    • copyguy1
      • Jul 2011
      • 142
      There is a soft sw that deals with dial tone detect or something along that nature. When it is set wrong it will work going thru the speaker button but not when using memory. There is a bulletin on the ar 208d that covers this you may want to check that.
      • BMSInc95
        • Sep 2011
        • 66
        the memory could be bad but this just started and the machine is 3 years old. it worked up untill the last 2 weeks. non of the soft switches have been changed. It will not direct send when the speaker button is pressed only memory send. I could try and do a memory clear.
        • mojorolla
          The Wolf
          • 2609
          Go into SIM 22-10 and check for the memory chip. If it says "none" under fax memory, you have bad memory. You could also try this: power the machine down. Disconnect fax unit, and power back on. Enter SIM 66-10 and clear the fax memory. If it won't clear, again, bad memory. If it clears, power down, re-attach fax unit and try again.
          • BMSInc95
            • Sep 2011
            • 66
            will try memory clear and let ya know.
            • BMSInc95
              • Sep 2011
              • 66
              Customer had changes made to their phone system and i didn't know it. changed soft switch 53 bit 4 to dial even if dial tone is not detected. working now.
              • mojorolla
                The Wolf
                • 2609
                Thank you for posting the solution.
