Sharp al-2051 digital copier / printer problem!!!!
  • Thabto
    • Aug 2025
    Hi
    Bought this copier some months ago. Everthing has been fine until the moment the toner cartridge ran out. I purchased another one online, only to see that it was not excatly the same with the one that I had. It fits perfectly, but does not have the "toner cartridge - chip" so my copier can not recognize it though it's a 100% original Sharp toner, I think it is meant to be used on another copier maybe a Sharp AL-20** , I don't know. So I emptied the contents of the new catridge into the old one. That is when I realized a new problem, the copier still detected the toner cartridge as empty. The toner catridge chip, of course. So I would like to know if I can do anything about this. Is there anywhere I can buy the chips only? What else could i do? Is there some service code I can type in? Please let me know.
    • 23010
    Re: Sharp al-2051 digital copier / printer problem!!!!
    The best thing you can do is buy an OEM (Sharp brand) cartridge that has the correct CRUM chip. You won't have to empty anything. For the $10 you saved buying the generic refilled cartridge, you have spent how many hours of your time trying to make it work? What is your time worth?
    You seem like a semi-intelligent person. For me, the real question is: Why are you even asking? Isn't it obvious? =^..^=
