AR286 with code f2-31 after adding Toner...
  • postalguy
    I could use a service manual for this machine also.
    Basically, it asked for toner so I gave it what it wanted, now its asking for a service with code F2-31.
    Can we remove this code, or did I screw something up? All help is appreciated.
    thanks guys...
  • ZOOTECH
    Senior member of CRS
    • 3377
    Your toner add roller is worn - dumping toner into developer. Replace foam roller and seals in toner hopper, should take care of trouble. You may have to replace developer and re-calibrate.
    • mnm
      • Jan 2008
      • 23
      I have the manual for this machine. I could email it to you however it's about 8.6MB
      • postalguy
        I have a gmail account that will take it I'm sure... I'd appreciate it.
          • 23010
          There's nothing I can add to the previous posts. Just wear your black shirt. Dumping the hopper can be messy.
          • JDE75
            • Apr 2007
            • 24
            You need to replace toner roller nrolp1211 and the seals. Then you should be okay. What I have noticed is the toner roller goes bad, it's a spogy roller and once you replace it you should be fine.
            • DINGO
              • 661
