MXM550 F2-31
  • sharpie
    • Feb 2011
    • 182
    MXM550 F2-31
    I have a MX-M550n that gives a F2-31 code. I have replaced the charge corona, swapped the PCU, HVPS, LVPS, the wiring harness to the corona connectors, left door unit and process unit with a working machine and still get a drum coated with toner. I do not see anything else in the wiring diagram that would effect this.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: MXM550 F2-31
    Clean off/replace your image density sensor and run sim 44-02.
    • sharpie
      • Feb 2011
      • 182
      Re: MXM550 F2-31
      The procon adjustment just comes up with the same trouble code. In SIM8-2 with the door cheated I usually can hear the corona and see the glow, but I am getting no output to the corona.
        • 23008
        Re: MXM550 F2-31
        Are the drum mark and toner density sensors plugged in and clean? How many copies on the drum? =^..^=
        • TennWalker
          • Apr 2007
          • 72
          Re: MXM550 F2-31
          I am with BlackCat, I have seen this and it was a loose connector in my case.
          I thought I was getting wiser as time went on... I now realize I am just getting older.
          • BMSInc95
            • Sep 2011
            • 66
            Re: MXM550 F2-31
            That is a drum sensor error. if you replaced the drum unit you should do a 44-2. Also if you had the drum unit apart then there is a connector on the rear frame side that has to be unplugged to open the unit maybe it didn't get plugged back in. hope that helps.
            • sharpie
              • Feb 2011
              • 182
              Re: MXM550 F2-31
              Thanks everyone for the input. The drum had only about 45K on it and the problem was a coated drum on power up. It wound up being the drum - not taking a charge after a power outage???? It makes no sense to me but that fixed it!
                • 23008
                Re: MXM550 F2-31
                Congratulations! The drums that I've seen code out were scratched through the drum mark so that it didn't read properly, usually with very high count (400k+, well beyond what you'd consider a useful life).
