AR-M455 CQ Stumper of The Year
  • Buddy
    • Aug 2009
    • 285
    Allright, I give up. I have a 455 (Imagistics version) that is making copies with faded areas along the back side (single-sided). It's an image that looks like a weak mag roller, or the mag roller is missing dv on it. When I run the internal test pattern of gray bars I get it and I also get it copying from the glass.
    Parts I've changed: Drum, charge unit, developer unit (a new one with fresh dv), transfer roller. I have taken the laser out and cleaned it inside and out. I have not touched the fuser because its fusing OK and the rollers are clean.
    HELP (I've got a very P.O.ed customer.)
    Thanks in advance.
  • Silvertoast
    • Feb 2010
    • 270
    Re: AR-M455 CQ Stumper of The Year
    have u tried holding preasure against the side door while it is making a copy? have seen alot of these were the door is warped or not closing tightly causing poor copy quality. usualy lite grey banding, but could cause other problems worth a look if it is the problem u will need a new side door
    • Buddy
      • Aug 2009
      • 285
      I did trying holding the door, but it didn't make any difference.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1887
        What about the gear on the transfer roller. They'll do that. I've started replacing them whenever I do a PM.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • blazebusiness
          SanDiegoCopierRepair.com
          • 1257
          Thanks in advance.
          Please post an example. Sounds like you've checked all the right stuff. I would have suspected dv unit or laser also.
          • Buddy
            • Aug 2009
            • 285
            Yup, I checked the gear when I replaced the transfer roller.
            • Buddy
              • Aug 2009
              • 285
              Sorry Blaze. I didn't bring an example home, but just picture cloud shaped, light areas on the back edge about an inch by two inches and sometimes smaller. And there's no pattern.
                • 23009
                If you're not sure about the transfer gear, the machine will run normal 20# paper stock without the gear. That's the test. Heavy paper requires the gear.
                Also check to see if the machine is level front to back. If the machine is high at the back, the mag roller will run bare after only a few revolutions.
                I've seen a scratched drum cause that.
                On one occasion I reseated the connectors to the laser, and to my astonishment the copy cleaned up.
                That's all I've got. =^..^=
                • divad2k1
                  • Sep 2010
                  • 147
                  Had this problem a few times and replacing the LSU always fixed this.
                  • lky1978
                    • Mar 2009
                    • 483
                    possible lsu....
                    or better upload an example to us
                    • TennWalker
                      • Apr 2007
                      • 72
                      I agree with the others based on what you have replaced. The LSU has resolved issues like this in the past for me.
                      Let us know how things work out.
                      I thought I was getting wiser as time went on... I now realize I am just getting older.
                      • Buddy
                        • Aug 2009
                        • 285
                        Turns out I did bring a sample home. (Occasionally I'm not as dumb as I think I am.)
                        Please see attached.
                          • 23009
                          Good sample. In my interpretation, you definitely have a laser problem (based on the geometric light areas in the main-scan direction, but not all the way across the page), and possibly secondary developing or dirty laser optics problem (based on the graduated lighter area toward the back edge of the page). =^..^=
                          • Buddy
                            • Aug 2009
                            • 285
                            Thanks Blackcat. I'll be ordering one.
                            • lky1978
                              • Mar 2009
                              • 483
                              viewed your attachment, is LSU problem.For me, i ll open up the LASER unit and look at the polygon motor surface got"cloudy" or not.If got just clean it before change the new LSU.
