AR-BC260 smudging prints before fuser
  • Jaws
    • Oct 2007
    • 236
    I have an Architect that prints a lot of 11 X 17 prints. And the paper is bowing up/or being pulled up and rubbing on the metal brackets that hold the drums. Thus causing the toner to smudge before it reaches the fuser. I checked Sharp net for a tech bulletin and could not find a solution to this problem. Maybe I over looked it, or maybe I am thinking of another machine. But, I could of swore I read something about speeding up or slowing down the fuser to stop this bowing up action. Anybody ran into this problem.
    • 23009
    Fuser Speed.
    The fuser motor speed is adjustable in simulation 48-06-D. The default is 85. I personally have never had to adjust it , but in class some time was spent explaining that the paper can buckle up if the fuser speed is too slow. Adjust in single increments. And no, I don't know if higher is faster or if higher is slower. Guarranteed which ever way you choose to adjust, it will be the wrong way. That's the rule.
    • choicecopyguy
      • Mar 2006
      • 111
      Blackcat where did you go to class on this one? Chicago?
      • Jaws
        • Oct 2007
        • 236
        Seems to be fixed will know more tomorrow.
        The customer uses the top tray for 11 X 17 which is probably not the norm.
        All my other BC customers use the bottom tray.
        Anyhow, I went today and the customer says it only happens on the first copy after it comes out of power save mode. So, I lowered the speed number to 80 from 85 on long paper and the smudge went away.
        I set power save mode to one minute for testing purposes. But, I am not sure if this will have the same effect as the first copy in the morning.
