Problem with the fusing unit MX-C311
  • davidcorp
    • Nov 2011
    • 16
    Hello,
    I've a problem with a MX-C311, sometimes happen this error code: l4-16 (fusing unit).
    I've verified that the pressure release control lever (MLEVP1113FCZZ) is broken. I've also verified that is very very hard to move the "ring" in the pic. It's normal?
    Davide
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: Problem with the fusing unit MX-C311
    Absolutely normal, unfortunately at my location we've come to expect it from any older C311. The MXC32HK kit replaces all the fragile parts these fusers are known for, however you're looking at a lengthy and involved rebuild.
    Keep a stock of MXC32FU1 on hand and just be ready to shell them out en masse.
    • davidcorp
      • Nov 2011
      • 16
      Do you think I've to change the fuser or only the broken part?
      I'm not a reseller, I've to find the fuser unit (220-240v) for my copier.
      Davide
      • Akitu
        • Oct 2010
        • 2595
        If you're willing to put in the time for it, the flag can be replaced sparing the fuser. Just be sure to use the part number MLEVP1112FCZ3 as it is the improved pressure detect release actuator.
        • brewster67
          • Jul 2011
          • 167
          If the fuser is hard to turn I would check the bearings on the heat roller. The first models of this fuser had these bearings fail alot. If you try running a fuser with bad bearings to long it damages the drive gears in the copier.
          • mojorolla
            The Wolf
            • 2616
            In May of 2010, Sharp added a rib to the pressure release detect actuator that was supposed to prevent the L4-16 code. Even with the retrofit, they still shatter. Every time I have had this code, it is one of three parts: MLEVP1112FCZ3, MLEVP1113FCZZ, LPLTP7869FCZ1. As mentioned already, the bearings on these things are known to fail. If it is hard to turn by hand, most likely your bearings are shot.
            • travi
              • Jan 2008
              • 129
              Looking at your picture it appears that the bearings for the heat roller have failed. If you are not a technician I would recommend getting a new fuser, MX-C32FU for 230v. You also have to check the gear that drives the fusing unit, NGERH1982FCZZ.
              • davidcorp
                • Nov 2011
                • 16
                What do you mean with "it appears that the bearings for the heat roller have failed"?
                • travi
                  • Jan 2008
                  • 129
                  It looks like the gear teeth are rubbing against the cover. I cannot be sure because of the angle of the shot. If it is touching the cover then the bearings have come apart. You either have to rebuild the unit with a MX-C32HK or replace it with a new unit. You cannot order just the bearings because Sharp changed there diameter.
                  • davidcorp
                    • Nov 2011
                    • 16
                    It's only the angle of the pic, it's not against the cover.
                    It's only hard to move.
                    • Toner Boy
                      • Aug 2007
                      • 365
                      If its hard to move, bite the bullet and plunk down for the whole fuser unit as suggested.
                      • davidcorp
                        • Nov 2011
                        • 16
                        I have not understood what do you mean with "bite the bullet and plunk down for the whole fuser unit as suggested".
                        Could you explain me?
                        • Toner Boy
                          • Aug 2007
                          • 365
                          The labor time and parts costs you'll invest trying to fix your problem would be better spent on replacing the entire unit in 5 minutes.
                          • davidcorp
                            • Nov 2011
                            • 16
                            Ah, but the repair parts are 20 euro, but the fusing unit is about 350 euro.
                            Maybe I can try to repair...
                            Davide
                            • mervyn
                              • Jul 2011
                              • 90
                              You ask for advice but wont take it when its given , you will end up replacing fuser , but go ahead and spend lots of time trying to repair the old one .
