Imagistics 3511 (sharp 450) with e7-90 error code/noise inside...
  • THEGUY
    • Jul 2025
    [Dead] Imagistics 3511 (sharp 450) with e7-90 error code/noise inside...
    Service manual states "commmunication error" between PCU and ICU as source/cause of the error code.
    What has your experience with this code been in the past? ICU circuit board issue? Other? Machine is down/inop and customer states tht there is "noise" in the front of the copier.
    Thanks in advance.
  • bilyahn
    • Dec 2006
    • 1470
    Re: Imagistics 3511 (sharp 450) with e7-90 error code/noise inside...
    Sharp shows most likely cause is a corrupt ROM on PCU. Have only had this once that I can remember and updated firmware was our fix. As for the noise it will all depend. A lot of times the customer states a noise and it is just the toner nearing end of life but these do have a problem sometimes with waste toner containers being full. Will need some more information since there are a lot of things that can cause "noise".
    Good luck.
    Bil
    • lky1978
      • Mar 2009
      • 483
      Thanks in advance.
      you better go to check 2 earth springs inside the ps unit are missing or not?
      • THEGUY
        NOISE was the front fan (replaced)... after that, Phantom faultcode didn't return..machine- ok.
        Thanks for reply.
